fullvietFX
- Sep 1, 2004
I'm new to the SSD scene and was wondering which one I should get. There's a sale at a local computer store for the OCZ Summit MLC SATAII 2.5" SSD 120GB. What do you guys think? OCZ or Intel?
You cannot just say "OCZ or Intel." Both companies make different drives, there are some good OCZ and some bad OCZ. There are okay Intel drives and then good Intel drives.
The short answer is: OCZ Vertex or Agility, or Intel X-25m Generation 2 (G2).
Alright I'm confused again.
OCZSSD2-1VTX120G - $576 (Vanilla Vertext)
OCZSSD2-1VTXA120G - $436 (Mac/Apple version, Vanilla vertex with a fancy sticker)
OCZSSD2-1VTXT120G - $483 (Probably the Vertex Turbo. Overclocked controller)
There is also a Vertex EX, which uses SLC flash instead of MLC flash. I'm not convinced that the "upgrades" are really worth it. Do some price shopping, you'll probably find better prices. Look into Bing cashback as well.
It puts out some heat, just not as hot as a hard drive though.SSD puts out virtually no heat correct?
Thanks for the clarification. These prices are Canadian, so they might seem a little high to you. One last question, do these drives support TRIM? Also thanks again for your help.
