Which sound method should I take?
Ghostface Killah
I am making a new computer, and I have three options I can take to upgrade my sound.
My speaker system is the Logitech Z-5500. It is connected to my computer with the three direct cables, the optical cable slot is used for my Xbox.
The options:
1) I can use my current Sound Blaster Audigy card and have the speakers connected via direct cables
2) I can use the onboard sound on the mother board, chipset Creative sound Blaster Live 24-bit H/W audio and connect it via Digital Coax cable
3) I can do the same method above but with a different mobo audio chipset, the Realtek ALC850 and connect it via Digital Coax cable
Which method should I take? Which will sound the best?
Oh, and which would be better:
Creative sound Blaster Live 24-bit H/W audio onboard audio
or
both connected via direct cable, which would sound better?
You know, all these questions can be answered on your own with a little emperical study. Try it and find out! Doing comparisons is a very educational process. Indeed, most would say that regarding audio, direct comparison is the BEST education. Check out the FAQ.
The problem is those questions are the path that will take me to either spend 180 bucks on a mother board or 130. I need to know, and obviousley I don't have it right now so I can not to do hearing study.
Sorry, I thought you owned them both.
The soundcard will sound better. Since you own an Audigy, it makes little sense buying a MB for its super-special onboard sound.
