Which should i get?
ral1239
Ive had this BFG 6800 vanilla for a while so i decided to overclock. Now its producing more heat and i was wondering what would be the best cooler for it or should i say decent cooler for it?
zalman vf700cu would be a cheaper solution that works pretty well, same with the nv silencer
I'd say zalman or stasis. Those nv silencers are pretty much crap if you ask me.
