-(Xyphox)-
- Sep 9, 2004
Which Setup do you think will perform better?
Dual 256 mg Nvidia 7900 GS in SLI
or
Single 512 mg ATI X1900 XTX
or
Yeah, it gives use the expandability for the future. I'd say the X1900XTXHaX said:go with the x1900xtx, i believe it performs better according to a thread somewhere.. i'm not quite sure.. im just guessing.. but look through threads.. plus if you get a x1900xtx.. you always have the option of another upgrade to crossfire
chinesepiratefood said:where do you find a 7900gs other than the mobile ones...
