Which setting do i need to play around with?
the madcow
I have a quick question i hope you guys can help me out with. When I'm taking pictures most of the time the lens picks up and focuses on just half the object while blurring out the remainder of the pic. What setting do i have to change to make it so all of the object and background stays in focus. Thanks for the help.
I believe this is the depth of field you're talking about, and is perfectly normal. It depends on what type of camera/lens you're using. The more info you post the better.
the camera is an EOS 20 d and the lens is a 17-40mm 1:4 L USM Lens is this the information you need
It's aperture, or F-stop which is what the above posters have been talking about. However, when you increase F-stop/aperture, you generally have to compensate by decreasing shutter speed or increasing sensitivity since higher F-stops decrease the amount of light let in.
Lower the f-stop, the more shallow the depth of field. I'm not familiar with the 20D's controls since I don't have one, so you'll have to look at the manual to see how to change aperture. Though I can guess you spin either the front dial or the rear dial.
Thanks for all the posts. I went and order the book because it looks like i have alot to learn.
