Dec 11, 2007 #1 A axlrose n00b Joined Dec 7, 2007 Messages 18 Their are three [3] choices to monitor my CPU temp. The three are 1. "AMD K8 Sensor" 2. "IT8712F-1" OR 3. "LM99" ?? Which one is correct to measure my CPU TEMP? It's a ASUS A8S-X Motherboard and AMD 64 3200+ Venice 2Ghz CPU
Dec 12, 2007 #2 A axlrose n00b Joined Dec 7, 2007 Messages 18 Please bear with me on this one folks. I simply am asking which sensor is accurate, nothing about whether or not it is an acceptable temp. Here is the scenario:Using SPybot for about 8 minutes. Each Sensor is labled in this image. http://img98.imageshack.us/img98/2713/sensorswl8.png Which Sensor is accurate? Which one should I be using? I really do appreciate your help thus far and in the future.
