Which secure erase software to use for C300 ?
nakedhand
I have a Crucial C300 that needs a secure erase. I recently reinstalled windows, did a quick format (bad idea), and since then the system have been significantly slower.
So I am looking for the best possible secure eraser fit for this drive. Since it´s fairly popular here I thought some of you guys might have a few suggestions?
Freeware would be nice.
I would use Parted Magic, which has a utility for erasing disks.
You can even use ZFSguru. :D
But take note to connect the SSD to a normal AHCI or IDE controller. For HDDErase.exe i guess your controller should be set to IDE. And yes TRIM can pass on both IDE and AHCI modes.
As for invoking a "secure" erase, any linux live distro would do.
Why do you put "secure" in quotes?
I assume you are thinking of issuing a secure erase with hdparm? It is a little bit involved, but should work. Some configurations will not work with a NULL password:
https://ata.wiki.kernel.org/index.php/ATA_Secure_Erase
HDDErase may also work, but I have found that the BIOS of some computers just is not compatible:
http://cmrr.ucsd.edu/people/Hughes/SecureErase.shtml
He probably means that 'secure erase' used to be a command that prevents data recovery, while for SSDs this is used simply to restore performance but not destroy existing data. Secure erase does not write to all NAND surface, it just resets the mapping table so the SSD is regarded as unused or 100% free visible spare space.
Probably it would have been better to call the 'new' erase method something like 'performance erase' rather than the existing 'secure erase' which was meant to destroy data making it unrecoverable.
"secure erase" is the name of a specific ATA command instruction. It is up to the ATA device what actually happens when it receives the ATA secure erase command. In the case of SSDs, they generally reset their internal LBA/flash-page mappings to a factory fresh state, and probably some take other actions as well, depending on the specific firmware implementation of each SSD.
The point is that on SSDs, a secure erase performed does not guarantee that (part of) the data cannot be recovered anymore. So what was once a security function, has now become a performance function but lost the 'security' aspect.
I believe that is why omniscence wrote 'secure' erase, because on SSDs it is not really a 'secure' erase anymore; but more like a performance reset.
Well, since the result of receiving an ATA secure erase command is device dependent, there is no guarantee, in general, for ANY device, SSD or not, that the data will not be recoverable after the device has received the command.
Im sadly on windows as I enjoy gaming with this machine. Had I still done serious work on my computer, I would have dived into Linux. Back when I needed it, it felt to complicated. What really scared me was a friend who was coding for the European Space Agency (specifically code systems on the ISS), who could not make his perfectly functioning DVD burner work in Linux. That scared me for ever... I know things are different these days and much more manageable.
Cool, it´s already on AHCI via ICHR10.
That´s how I meant it. Thanks for clarifying though. :)
When someone writes "linux live", the live part means that you run linux without necessarily installing it to your HDD. You can run it from a CD or USB stick, for example. Just temporary, to get the job done.
Yes, i hope all OS will get distributed with a LiveCD that is operational, and ability to install or even do some work from within the LiveCD.
Ubuntu is extremely useful; you can boot the livecd and get access to firefox (looking up stuff on internet) and disk partitioning (gparted) and other tools like RAID recovery.
Cool, thanks. I have zero knowledge of Linux. Sounds like something worth trying :)
