Which screw size for Push/Pull in AiO?
next-Jin
I’m looking to get a Fractal S28 and want to replace the fans with some Noctuas in Push/Pull and having a hard time understanding what screws I would need to mount the other fans.
Anyone know?
It doesn’t come in a Push/Pull though, it only ships with 2 fans. I don’t think it ships with additional screws for that type of setup.
i just do 2 screws for each fan. just take one to your local hardware store and match it up. spec sheet says its a 6/32 thread and its probably ~28mm long.
