Hi,
I only use my monitor to code with netbeans on Windows10. So the most crucial factor is high **font** readability. I use my screen 8+ hours per day so I cannot have blurry text, tiny font or grainy AG coating.
I would like to upgrade to 4k.
1) Which size do you recommand? 27 or 32
2) Which percentage (Windows scale) do you use?
3) Do you recommand a monitor (I have no budget constraint). My short list: EIzo EV2785, Dell U2718Q, Dell UP3216Q. But I am open to better monitors.
4) How many lines (netbeans) do you display? Currently I have 54 lines with a standard netbeans config and 1 line Windows taskbar.
Thanks a lot.
Thanks a lot.
