I am getting ready to upgrade from a 19" Benq 25ms lcd. I am going to get a widescreen monitor. I was looking at 4 of the sceptre monitors as I can get a good deal on either one. I was wondering if there would be much of a quality and/or performance difference between them. One is the X20WG-Naga
http://www.sceptre.com/Products/LCD/Specifications/spec_x20wg_Naga.htm
x20WC-Gamer
http://www.sceptre.com/Products/LCD/Specifications/spec_x20wc-Gamer.htm
X20WG Naga
x22wg-Gamer
http://www.sceptre.com/Products/LCD/Specifications/spec_x22wg_Gamer.htm
I I don't care about the hdmi as I will only use the dvi with my pc. The specs are very similar with a couple having a little better contrast ratio. Any input or ideas as to whether or not there would be a performance or quality difference when gaming? The prices I can get these at range from 199 to 299. If you have a better quality 20-22" monitor that you can recommend then please do.
x20WC-Gamer
X20WG Naga
x22wg-Gamer
