which sata III cable for ssd
the psu should already have the power connector. as for the data cable, they are all the same. there nothing special to the SATA cable. do note that there will be a difference in performance between a good cable vs a defective cable.
i hope this helps you.
You don't need anything special at all.
The PSU will have a cable/connection for the power, and either your motherboard and/or hard drive will (more than likely) have a cable for the data connection.
EDIT ... And if you don't have one for any reason, they're 99 cents on eBay! ;)
