melted_stencil
- Aug 4, 2002
I'm building a file server right now in a 4u case and am stuck on deciding which raid card to use:
Promise Supertrak SX6000
or
MegaRaid i4 IDE Raid card
The promise card is a 6 channel card with support for up to 6 drives and I added 128megs of ram. Also is a 64/66mhz part
The megaraid card is a 4 channel card but supports 8 drives (2xchanel). Onboard 16 megs of ram.
Feature wise the megaraid seems a bit better, supports more Raid modes at least (1, 2, 3, 5, 10, 30, 50)
Promise is just more baddass looking and has more ram. The megaraid doesn't support anymore than the added 16.
Another question I had: I have 5 hard drives now, with the intention of buying more. Can I add drives and have the card dynamically rebuild the array to be bigger?
Thanks
Dan
or
Thanks
Dan
