Sevenpants
- Jun 24, 2005
I've got a Lian-Li v2000 and I want to cool an X2 4400 and one 7800 GTX on a ASUS A8N-SLI premium, with possibly (though probably not) another 7800 in a couple months. I'll use Cathar's Storm from Swiftech, undecided GPU block, and either a D5 or DDC pump. I just can't decide what to do for a radiator.
I want enough radiator to cool the processor and GPU(s) down as close to ambient as possible. I don't want to cut a hole in the top of the case to fit a 120.2 or 120.3 radiator (I don't have tools or a garage, and I don't want to block my PCI/PCIe slots). I don't want an externally mounted radiator. I want to use quiet fans.
For those who are unfamiliar with the v2000, it has a 120mm fan mount in the bottom front, 2x80mm fan mounts in the rear bottom just above the PSU, and another 120mm fan mount in the rear midway up, right where the cpu sits. Here are pics from newegg:
one
two
So, I think I've got it narrowed down to two choices:
1. Thermochill PA160 mounted in the 120mm spot in the bottom front of the case.
- Anyone have any experience mounting this in a v2000? I don't think it would be a problem, but I'd rather not be the guinea pig either.
2. BlackIce Pro mounted in the bottom front and BlackIce Micro II in the 80mm spots above the PSU.
- How does using two separate rads compare to using just one larger one? Should I mount them one after the other, or put one of the blocks between them?
I could also put another 120mm rad in the spot in the middle of the back, but I think I like the options above better.
So, does anyone have any suggestions? Any better ideas? Am I going to get enough airflow through the current holes without dremelling out the grills? They don't look too restrictive...
one
two
