Zangmonkey
- Jul 6, 2005
I'm looking for a rack case which will fit a full-length GPU, two optical drives and two hard drives.
It's going to hold an Ivy system and a single GPU, does *not* require hot-swap sata.
My highest priorities are cooling design and build quality.
I know the Norco cases are highly regarded but it seems like mostly for storage servers and the like. What does [H] recommend?
I've used this case before:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811321002
thick steel and fair quality, and it comes in a longer version if needed.
