jesusFreak2o2
- Aug 5, 2004
Hey Guys I have a question which pump should i get. i am running two 120mm rads and am not sure if i should get the csys dual pump: http://www.dtekcustoms.com/index.asp?PageAction=VIEWPROD&ProdID=141
or the aquaextreme : http://www.dtekcustoms.com/index.asp?PageAction=VIEWPROD&ProdID=138
I dont have alot of room in my case so am looking for something small and i heard the danger den pump is the same as the aquextreme. so if someone can help it would be great. Thanks!
