Which pump should i use?
eo54
Eheim 1250 or Swiftech MCP655?
If i go with the 1250, i will get a relay so that i can use DC on the 1250
How's MCP650 compared to the 3?
Have you not considered a Laing DDC-12V? It's quite, has a great flow rate and is 12V :cool:
Out of the two you've stated I'd go for the Eheim.
I'd go with the 655, or any versoin of it that you can get there............... :D I'm a big fan of 12 volt pumps, been using D4s and now the D5 from when they were first released.
MCP650 n MCP655 diff is only in the adjustable nod ya?
If i get a 2nd hand MCP650.. i perform same as the 655?
I was slightly more supportive for Eheim for their reliability.
Performance levels between the 2 are close, but the D5's a somewhat better . Noise levels are also lower on the D5 and toy already mentioned the adjustment knob............. :cool: Get the D5 (MCP655).
