- Sep 24, 2007
Ok heres what I was planning on getting:
Cooler Master RP-650
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171014
BUT, if I HAVE TO (no i really dont want to spend this much but), I can buy either one of these:
OCZ Stealth Extreme
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3092557&CatId=1483
Coolmax:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1543967&CatId=1483
Ultra:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2974508&CatId=1483
Could you guys tell me if the cooler master is a piece of crap or not? If it is, which of the other 3 PSU's should i get?
I really don't want to spend 70 bucks, I cant justify it.
Thanks, Adam
OCZ Stealth Extreme
Coolmax:
Ultra:
Thanks, Adam
