which psu should i get?
I've never heard of the other company, but Antec is one of the best. Besides, it's more powerful, which you will need if you are thinking about doing SLi or something. If you are thinking about upgrading to a dual video card option or something in the future, it might be a good idea to make the sure power supply you buy supports it. I didn't check the specs on this one, so if it does, ignore that comment. Anyway, my vote would always be for Antec. Their products are definitely worth the extra money. Cheers
For what system?
Both the Xclio and the Antec are made by CWT.
