Which program is reading correctly the temps?
Nokia
Real Temp 2.4 tells me @load
47c
44c
38c
46c
cpuid hardware monitor ver 1.08@load
tells me
52c
50c
43c
51c
Core temp ver 0.97.1@load
tells me
54c
50c
43c
50c
@loads @ stock voltages
So which program should I believe? I like to overclock a bit higher but I need to know what temps are realistic.
thanks for you help
Nokia
Coretemp and Hardware Monitor are most likely your best bet. First of all they're both reporting about the same temps....with 2 programs against one I'd take the two that match. Second, Coretemp and Hardware Monitor have a great track record around here and are generally considered to be 'correct' and report accurate temperatures.
