Which Processor?
SoloSid
Hi All,
Great Site here...
First post ...so hello everybody....
Question..... How do I know what processor I can upgrade to?
Background..... I have a 5 Zone Whole House Audio setup using. Girder5 & NR2
on a Vista32 HomeP System with a Delta1010 Audio Rack this is fed to an Onkyo605 & Teac AG-980 various IR & RS232 controlled 'bits & bobs' accessed by two 19" Elo 1939l touchscreens and a Nokia770 Internet Tablet . this all fits into a 23up Rack. I have swapped everything over to a smaller case and upgraded the power supply and increased the memory to the advised 2G (paired).
Then it dawned on me that the processor would not be quick enough?
the motherboard is a Asrock 775i65GV
bios version is P1.90
pcb version??? how do I find this info???
graphics card is a nvidia geforce7600
processor at present is a intel celeron 2.66GHz
I hope that enough info for answers if not ask away...
Cheers
Mark
You are running a 5 year old board and an old p4 based celeron. The Asrock is a 775 board, but I doubt it will handle a core2duo. I went to Asrock's site and their bios and driver updates for this board wouldn't even load. If you want to upgrade, you may need to replace your motherboard too. Others can chime in here.
You would certainly see an improvement in multimedia handling if you upgraded. That said, what about your system isn't working for you?
Would you suggest buying a new ready built PC? if not necessary which MB & Processor would you recommend
to help assist you in your views I don't mind buying the best if thats what needed but I am quite happy buying something that is capable for my needs...I just don't know the difference ?
the system works OK.... just hangs sometimes
I want to use the screens as TV's to stream cable (using PCTV to go box at present) this stutters all the time
hope this helps
Mark
Just like to add I'm in the UK so any hardware needs to be avialable here
Cheers
Mark
Also to add..
I would need at least 4 slots (pci I think) for video card, delta1010, RS232x4 (2 cards)
cheers
Mark
Mark,
4 PCI slots probably rules out most OEM builds these days. You should check the online retailers in the UK an see if you can find a modern board that meets your needs. The build gwarren suggested would probably do fine for your needs.
Hi All,
Can anyone reccommend a MB that has 4 slots the ones above seem to be mini ATX?
Cheers
Mark
GIGABYTE GA-P31-ES3G
looks like you have 2 pci to serial cards and an audio card
the board you have now has 3 pci slots according to the model you posted
the video card you have, based on what you described is agp
GIGABYTE GA-P31-ES3G - 60
9500gt -60
RAM -20
cpu-72
so about 200(us) for the upgrade
here's another option
ASRock 4CoreDual-SATA2 LGA 775 VIA PT880 Pro/PT880 Ultra ATX Intel Motherboard - Retail
ddr or ddr2
agp or pcix
core 2 support
4 pci slots
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157115
or pickup a pentium d 950, Going from a celeron to a dual core pentium d is a huge speed jump
dont' know about stock where your at, there's always ebay
Mmmm Thanks SpudsDude,
Just reading the comments on the newegg site and they talk about old agp cards
Is there a new type out...if so what do you reccommend
I can get this board in the Uk for £50 (uk)
what processor do you recommend for this MB
and what Graphics card?
sorry for all the 'dumb' questions but I've got 'tubs of stuff' I can't use.....
cheers
Mark
