Which processor driver for the fx62?
Galvin
Maybe i'm making this more confusing. There is a dual core processor driver for X2 series cpu. But then there is a processor driver for the FX series. the FX62 is a dualcore cpu. Pretty much the same as an X2 except more cache and an unlocked multiplier.
Right now I have the FX processor driver installed. This the one I should be using for my FX62 even though its not a single core cpu?
thanks
The driver probably containes a different inf identifying the 2 different CPU's. As far as I know, that's the primary difference.
technically speaking you don't need any driver windows XP SP2 will support it natively.
You only need to install the "driver"/hotfix if you're having problems with the system specifically in gaming.
