Which Power?
i kno u guys prob. get this question all the time but which brand provides quiet but does not produce too much heat and also has stable voltage. TT, ANTEC, ENERMAX, Zalman?
it shouldn't produce much heat going into the case, but i can't be sure...
quiet wise, as long as you use the fan bus for the PS, it should be adjustable to taste.
cheers,
dave
