Which power supply should I use???
Lyquist
I have two power supplies...one is a 450W Antec Smart Power and the other one is a 430Watt Antec TruPower. WHich one should I use for my conroe rig??? I'm asking the experts which one is better. Thanks in advance for your help.
_Korruption_ said:
Which model exactly? The TruePower II 430W?
Yes, it is the True Power II 430Watt. I don't know the exact model of the smart power. It is the one that comes with the Antec Sonata II case on newegg.
How do you know that the TP II is better than the smart power?? I'm not questioning your intelligence, I just honestly don't know much about power supplies.
Easiest answer is that the TP II is a higher Antec line, than the SP II, which is Antec's economy line. ;)
killingfield1975 said:
I heard rosewill makes great PSUs :D
You heard wrong. :rolleyes:
Rosewill doesn't make anything & they rebadge so many different brands that it is a crap shoot at best.
None are good, some are just worse than others. :(
I do believe that may have been a sarcasm ;)
Or at least I hope so :D
