Which power supply is better?
I'm between 2 power supplies and can't decide one way or the other.
These are the two I'm looking at:
The Corsair HX620W
or
The ABS Tagan BZ700
Which would be better for my system?
My rig is in my sig. I will be upgrading to a second 8800GT and 2 more gigs of ram. Also I may be adding a second hard drive. I may be setting up liquid cooling on the 2 graphics cards. I also want to make sure the wires are hidden well so i want to make sure i get a PSU with good wiring. I may even go with the BZ800 if i need to, but I'm looking the $170 preferably.
I just want to make sure i have the proper wattage(with room to upgrade my system), number of connections, and a good stable modular power supply.
Thanks in advance!
I would go with the Tagan since it has more power on the 12v rail and you are adding another video card. They are both very good psu's and you can't really go wrong with either one, but I would prefer to have the little bit of extra power in your situation
I'm more looking at the BZ700 as apposed to the BZ800. Is there any real difference between the two other than wattage? Also I'd like to get more of an opinion as to which would suit my system better.
The rails on the Tagan are properly distributed.
As opposed to some Enhance and Enermax OEM multi +12V rail units. :(
