I have been reading and some people are saying that my OCZ gamexstream 700w isn't enough for 8800gtx SLI. If I decided to go SLI which of these power supplies would be a better to get and not be overkill for an SLI setup and future SLI setups (eg. 9800gtx SLI and beyond for a few years)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817256006
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16817256007
Would it be worth to spend the extra on the 850w. My brother has the 750w and a single 8800gtx as well. His power supply is SLI certified for 8800gtx SLI on www.slizone.com but mine isn't.
What do you suggest?
Thanks
or
Thanks
