Which port has the highest traffic?
cxz001
Anyone know how to see the port with the highest traffic on a NETGEAR RangeMax router? Im trying to limit my cousin's downloading. But I'm not sure which port his program uses. My router does have QoS..
Torrent clients are difficult to block or limit on a port basis, because they're designed that way; as soon as you block a port, they'll switch to another one. Disabling UPnP in the router may help. Using OpenDNS and using their blocklist for P2P/Filesharing may help too. Having a chat with your cousin may be even more effective.
I tried talking to him, but he just cannot break the habbit of torrenting / downloading 24/7 using up all of our bandwidth.
He uses Rapidshare a lot too. Is there anyway to block all traffic to rapidshare on his computer through router configuration? I don't have access to his computer.
Depends on your network configuration. If all your DNS queries go through the router, you could hijack the domain and return the incorrect IP for it.
Sounds to me like your only effective option is going to either be convincing him to stop being an asshole and put limits on his bandwidth use, or force him to do so by using QoS. QoS on little home routers doesn't tend to be very good, but it's worth a try, and something as simple as limiting his IP to half your upstream bandwidth or something may be enough to do the job. Read your user manual :D.
He's on wireless too, so is there anyway to limit the wireless output?
Well that's the thing, our wireless modem doesn't need an antenna... It's a Netgear RangeMax. And I don't want to disconnect him completely... Just reducing his max download to maybe 150kb/s?
Somewhere in the wireless configuration you should be able to set it to 1/2/5/11/etc. mbps.
That's a great idea. Limiting him at the AP seems to be the best choice.
When my roommate pulls this shit I just block all outbound traffic destined to ports 1024-65536 from the LAN, but I don't think your Netgear can do that.
Send yourself a letter addressed from your cable provider stating that you may lose your internet access and may be investigated for downloading and uploading copyrighted material, and then show it to your cousin. Put his MAC address in the letter as well.
do you have an old pc laying around? install something like untangle. block peer to peer all together and then allow yourself and your machines as a bypass of it. Then you could just turn your router into an access point and turn him off. Little involved, but another option
slowing down his wireless connection seems to be the best idea honestly. restrict him to 11mbps (wireless-b) or slower
Does he help pay for the internet at the house? If he does not, cut his access and say be respectful or go without. If he does help pay for it, your options are as stated in the thread.
because its his brother, im guessing the OP lives at home and doesnt pay for internet either, may not even pay rent? idk..
but anyways, slowing him down will likely go unnoticed as he wouldnt have a problem browsing most websites, he'll just be limited to how much bandwidth he can use
you can also set QoS to give priority to your computer/application
I used QoS and limited the wireless to B only, which is 5mbps i think, but still he can get upwards of 500kb/s... that's a lot of bandwidth considering I only have a 9mbps line lol.
11Mbps is ~1.4MBps
That may be more then your bandwidth I suppose, the QoS should fix your issue. See if you can lower the wireless speed even further
You could also try using OpenDNS as your dns provider. If you create an account and setup your network on it (you can use dynamic IPs as well), you can block the domains completely at the DNS level. You could say, block rapidshare.com, tpb, demonoid, etc... and then he couldn't actually download the torrents in the first place.
You could also possibly go into his computer to his torrent software and force it to a specific port and QoS that port while also filtering common BitTorrent ports (6881-6889). If you want to see what ports he using for torrenting, you can also use Wireshark to detect packet traffic on your network.
Wireshark is a free program and quite good as a network sniffer.
as someone stated before, why dont you just block the torrent sites for his mac address/ip address. He is getting the torrents form somewhere. Make it very inconvenient for him to download. You can also be an ass and just limit his time do even get on the web. If youre the administrator, you have all the power, use it.
Hmm, well, my question is, obviously you can virtually set any port other than 80 as your P2P port, how would I know which ports to close down?
Is there any way to block every port except for 80?
Is there a function in router that allows you to see which ports receives traffic?
first off.. your pc does not use port 80 to browse the internet.. port 80 is only on the receiving end
second, you could block the common ftp/torrent ports both incoming and outgoing imo, which may help your issue
