Which PCI-X to go with?
I have an ASUS A8N-SLI Deluxe MB, it lists the PCI-E as "2 x PCI Express X 16 (*SLI mode : x8 , x8"
I see newer boards like the ASUS A8N32-SLI Deluxe listed as "2 x PCI-E x16 with SLI support at full x16, x16 mode"
I am thinking about upgrading to a GeForce8800GTX (and maybe later on another one for and SLI) My question is, does the new 8800 come close to maxing out my MB PCI-E bus? Would having two 8800's max out the bus? I don't want to upgrade my MB unless I have to
Thanks
From what I have read, no video card on the planet saturates the PCI-Express bus to make a performance difference in SLI with x16/x16 vs. x8/x8. I'm sure someone will pop in here and say they get 500 extra e-penis points with a x16/x16 SLI config vs the x8/x8.
Oh and BTW, PCI-X is not the same as PCI-Express (or PCI-e as many call it). PCI-X is a server-oriented PCI slot. Might want to change the title if you are able to.
