Which PC case for Threadripper 3970x + muliple GPU PC?
professional loser
Any views on these or soemthign I am missing? I like clean design and not too much RGB bling bling.
Will be using AIO or air cooling. No custom loop.
Fractal Design 7 XL case
vs
Corsair Obsidian 750D Airflow
vs
Phanteks Enthoo Luxe
vs
Be quiet! Dark Base Pro 900 rev.2
vs
Phanteks Enthoo 719
I would like to keep it under $250-$300.
Thank you.
Are you including buying fans in your budget? The 719 is great, very roomy, but no fans included. Also great for when you realize that air cooling (or even the AIO) just isn't good enough to keep the clocks up and build that custom loop :).
7 XL would be second choice, or first if lots of storage is going to be put in there as well.
