Originally posted by OC_GORK
judging from the OC database @ overclockers.com it looks like i could hit [email protected] or [email protected] DO you think theese numbers are realistic?
Originally posted by subscience
I recommend the 2.4, 2.6 or 2.8.
But the best P4 for overclocking? The 1.6A.
So, with a 5:4 ratio for a P2.4C, that would be 3.0Ghz, correct? If I have researched correctly, doing this would require locking the AGP bus speed in the BIOS. But there must some tradeoffs using the ratios with the memory, aren't there?Originally posted by chrisf6969
you can OC fine with generic 3200... just use the ratios as you go up. I'm using the 3:2 ratio at 300FSB = 200Mhz ram perfect for 3200.
I think this is sort of the information I was looking for. I understand, given a specific ratio and processor, what the resulting output will be. The math isn't the problem. I was mostly curious if there were situations where a 2.4C @ 5:4 (3.0Ghz) would actually be worse than just running the 2.4C stock @ 1:1 (2.4Ghz).Originally posted by Arkanian
Of course benchmarking shows that a P4 2.4c with PC3200 using the 5:4 ratio get beat by a P4c3.0 with PC3200 using the 1:1 ratio. Moral is you want to run your MEM the same mhz as your fsb using the 1:1 ratio.
