Which Opty...170, 175...180?
hemi
Hey,
I see the 165's are sold out just about everywhere and the price is starting to creep as if they're leaving the market forever. I was eyeballing a 165, but now I see Newegg with the 170, 175 and 180 at $219, $243 and $299, respectively. (165's are still out of stock at the 'Egg)
I realize the 170 is the best choice from a cost perspective, but I'm wondering if the higher multi on the 175 or 180 would work best in my rig. Right now I have a 3700 (San Diego) that tops out at 10x270, so I don't know if it's the board (A8N-SLI) or the chip. If I am capped at 270, then my only shot of reaching 3GHz is with the 11 or 12x chips. If it falls short of 3GHz I'll be fine with that, but hitting 3.0+ would be gravy, especially since I'm not planning a platform upgrade for another couple years. Gotta get in on the S939 Opteron goodness before it's gone... ;)
Edit: Forgot to mention I'm running on water, FWIW (Swiftech Storm).
Whaddaya think?
Thanks! :D
Tom
Buy the cheapest. The A8N-SLI is a pretty good board for overclocking, you can easily hit 300fsb. I've got mine to do about 320fsb. The 170 has a 10 multipler which should be good enough.
Well, I hope the board will go to 300 (and the proc to 3GHz). I just ordered the 170 and a fresh tube of AS5. :D
Been a year since I've upgraded...can't wait to see what it'll do.
Thanks!
Tom
Chances are: they are leaving the market forever.
NordicRX8 said:
Good Luck with that chip... make sure to report back with your OC results! :D
Will do. It's scheduled to arrive on Thursday...and I happen to be home that day on vacation. ;) I'll post results on Thursday or Friday.
Tom
Woohooo! :D
The 170 arrived a day early...I came home to find it sitting in my kitchen. To top it off, it's a CCBBE 0610DPMW. If I'm gonna hit 3GHz, I think this might just do it. I'll be installing it either later tonight or tomorrow...
Tom
Status update - and I have a question.
It's installed. Came up and XP detected the new CPU, loaded the mulitprocessor driver and rebooted. All looks OK.
So I reboot, slide the bus up to 250. Boots @ 2.5GHz, stock voltage, no problems. I then load a couple copies of Prime95, set the affinity, and away we go. I'm using the tool Core Temp to monitor both cores, and here's the weird thing - Core 0 runs about 6C hotter than Core 1. I've heard of this before, but there are also a lot of people that say both cores run exactly the same.
Here's the lead in to the question. I'm using AS5 and followed the instructions to put a "3/4 BB" size drop of it on the core, then "twist" the heatsink. I'm running a water cooling setup with a Swiftech Storm, so all I did was a partial tighten (to make light contact), a twist in both directions, and then cranked it down. Even idling, it's a bit higher than the San Diego. Core 0 idles at 38, peaks at 51, Core 1 idles at 32, peaks at 45. Core 1 is inline with the Sandy, but 0 seems way off. Should I have spread a thin layer of AS5 over the entire IHS instead of using their directions? I was using Arctic Ceramique, and that's what I had done with it on the San Diego.
By the way, it's cranking along with Prime at 2.5. Trying 2.75 next. ;)
Tom
I used a very small drop of ceramique on my winnie, and with my XP90 I get very good temps even at 1.6 volts. So I think your ok with the amount of paste you used, but everyone has their prefferences so it might help spreading a little more around it. :confused: It also depends on the heatspreader. Maybe it's not perfectly flat and not making consistent contact with your water block? Hope this helps.
Edit. Also If I remember right, it takes a few hours/days for that paste to cure. So I think your temps might come down a little.
Yeah, I know it takes some time. Just wondering why it's inconsistent between the cores. I think I'll let it go for a few days - their guide says 200 hours of use, so it can take a while before it "breaks in". If it isn't closer within a few days, I'll re-apply.
Just finished priming for 30 minutes @ 2.5. Booted 2.6, then rebooted at 2.75. Been priming for about 10 minutes so far. Still at stock voltage. :eek: I can smell 3GHz, but I don't wanna get my hopes up just yet. ;)
I have 3 dual cores and have removed the ihs on all of them. Before removal, temps were about 5-8 degrees different. After, only 1-2 difference, plus overall temps dropped over 5c. Just took this shot right now. Here is my 170 @ stock voltage, full load, folding 2 clients. It runs 2.9 @ 1.5v, but temps go over 50c and I have to have the fans too loud. This is in my bedroom and I like it nice and quiet :)
The x2 3800 in my sig runs 2.7 @ 1.525, but is cooler. Temps are only about 44-45 at load. Both are cooled with a big typhoon.
BAM! Hit a wall. :mad:
Tried going to 2.85:
2.85 @ stock, failed POST
2.85 @ 1.40, failed POST
2.85 @ 1.45, failed POST
2.85 @ 1.50, locked during boot
Right now I'm at 2.8 @ 1.40. Doesn't look like it's gonna cut it either. Prime on the first core just croaked. I think I can get her stable at 2.8, which I'd be very satisfied with. 3GHz would have been sweet... (*starts looking for new motherboards* ;) )
4X4N: Thanks for the info. I may try removing the IHS if the temps don't fall in line.
Tom
I'm pretty sure it's the board. I went back to some old data I had logged benching and confirming stability with the San Diego (hadn't had it OC'ed in a while). It was rock stable at 10x275, but no higher.
Knowing this chip seemed stable at 2750 (10x275), I tried 9x300 (2700) - no POST. I then tried 9x280 (2520). It did basically the same thing as 10x280, which was boot into Windows, then crash. Tried both of those at 1.5v (max for this board, A8N-SLI Premium)
I have the RAM at /15 (timings loosened too) and HTT at 3x, so they're out of the equation.
I'm back at 2.75 @ stock voltage, running P95 on both cores.
So - someone recommend me a new board!!! :D I still think I can reach 3GHz ;)
Well the DFI NF4 Ultra-D is a known good overclocking board but it requires more tweaking (hence "tweak fun"). I actually have a spare one if your in the market.
Before you dump the asus though have you tried updating the BIOS? My A8N-SLI can do 1.6v. I'm currently have a opty 165 doing 9x305 at stock voltage 4x htt (I'll go to 3x once I do more FSB).
EDIT: Also check to make sure your PCI-E bus is locked.
As long as your LDT is low enough (read: 3x), then it's the board crapping out. ;)
JohnleMVP: I'm running the 1009 BIOS, which I believe is the latest for this board. I checked the US and Global ASUS sites last night before dropping it in.
I have the PCI-E bus set at 100, and the legacy PCI bus at 33.33. Not sure if there's any other trick to locking the bus(es)
2uantuM & tsuehpsyde: Yep, LDT/HTT multi at 3x - see my last post where I noted it and the RAM divider. The post before that has a cpu-z screenshot...HTT is only at 827, and the RAM at a leisurely 183. I really don't think that's the problem. :)
I really wish I didn't have to replace this board, but it seems I have no choice. If this chip didn't seem to have so much potential, I think I'd jump ship and buy a P5NSLI (err, make that a 975X board), E6600 and 2GB DDR2-1066. Of course the reason why I bought this was to do a "cheap" upgrade to last me a while. Having to buy a new board is gonna change that. :(
You can try a program called clockgen to find out if your PCI-E is locked. (There are probably other better suited programs but it works too) You can also try setting the PCI-E to 101 or 102. As for the bios I'll check the version of mine when I get home, but I can set my chipset voltage to 1.6 so you should be able to aswell.
My 165 got to about 2760ish without voltage and 2800 with +.025 voltage, but can't do 320x9 yet. However I check the board at 330x6 and it ran solid. So the board is good for a lot more then the 270-280 cap your running into.
E6600 is definatly a nice upgrade but $$$.
i have same stepping 165 that is running stable @ 3066mhz
what i can tell you from tweaking it for a few days, is that to get it stable @ over 3g it will need 1.6v , thats running @ 340 FSB , since you have the 170, it might need a little less voltage because of the higher multiplier , but i doubt it,
also , anything over 290fsb, the divider has to be set to 133, and the cas latency has to be 3 or higher, this can vary a little on different ram , but it might also be the sign of memory controller being maxed out at this settings, which will be the same on different ram if thats the case
also at 300+ fsb you might need to set the LDTvoltage to 1.4v to get it stable, under 300fsb 1.3v should be ok.
of course the HTT multiplier should be 3x and the timings 3-x-x-x,
ram voltage and timings will depend on your ram and the strenght of the memory controller , you have to experiment and figure that out on your own
also , mine is water cooled, idles 23*~25* , full load 45*-47*C
good luck
clockgen - forgot about that. I have an old copy somewhere from when I had an NF3 board. I'll dl the latest verson. Maybe that'll help figure it out...
RAM timings are loosened at 3-4-4-8 2T, 2.8v (Patriot 3200LL). I haven't really messed with anything else up to now.
I'll give it some more tweaking later today...but if all efforts fail and I can't get this board going, you guys might see a nice CCBBE 0610 in the FS forum. ;) Not like me to give up so easy, but I'm not buying another 939 board, even though I'm loving this CPU so far.
You can also try to isolate the problem first.
Set everything to the slowest settings then test individual components, MB max, CPU max, Ram max.
I'm nearly certain it's the board now. :(
I lowered the multi to 6x, left the bus at 270 (CPU at 1620). PCI-E at 101, PCI 33.33. RAM voltage bumped to 2.9, "chipset" voltage to 1.6, HT link to 1.25 (1.2 is the only other option). Booted into Windows and used ClockGen to see what it would do. I could slide the bus speed and the PCI-E and PCI buses would stay locked (also tried PCI-E at 100 just for fun). I could bump the bus to 275 and apply it, no problem. I then slid it up to 280, as soon as I click apply, hard lock up. Also fooled with the CPU voltage, but the net result was the same each time.
If anyone is interested in this Opteron, PM me. If not, it's going back to Newegg in exchange for some other stuff.
Thanks for all the help, I really do appreciate everyone's time, input, and all the suggestions! :D
Tom
Hulk said:
How many FPS did you gain while playing games?
Are you bustin' my chops or are you serious? The only game I've played in the past couple days is WoW. It loads faster and seems smoother, but it already ran well. I have a 7800GT in this machine and it has all the eye-candy turned up. I haven't played anything else yet. Overall, the system feels faster...obviously that's just better multi-tasking. :)
Tom
Just sold the Opty in the FS forum. I'll sure miss the little bugger, even though we only spent 38 hours together...*sniff*. :D
Also just scored an E6600 that the seller claims goes 3.4 @ 1.4v on water. Let's hope I get a good board and can get it there! :rolleyes:
Thanks again everyone.
Tom
