Which option should i go for?
lee0539
I currently have the raptor 74GB which i used for awhile now so it isnt the newer one with the slightly larger buffer. I was wondering which would be the best option to have my computer running the smoothest.
To buy another 74GB with raid 0 and install OS and programs onto that harddrive.
OR
To buy a 150GB raptor and install all my programs onto that one and use the 74GB to have only vista OS on it.
OR
won't make much a difference so best to just get a large sized harddrive (ie 500GB 7200 rpm) instead and use 74GB for OS only.
I'm all about speed, personally I have two raptor 74 raid 0.
You should do what fits your needs, if you need more storage then almost anything is cheaper per GB than a raptor.
