Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I want to get a water-cooled system and i need help choosing between a Koolance system and a custom one using DangerDen components. Which one cools better???
The Koolance system cools pretty good................ A cooling system put together from high end parts from a company like Danger Den will cool better if put together correctly with the right components,,,,,,,,,,,,
I'm putting together my own system primarily consisting of Danger Den products because I'd like to get the best performance possible out of it. I know it'll outperform a Koolance system. Plus it'll be cool to put everything together myself..a sense of accomplishment, if you will.
