I am looking for the best gaming headphone mostly for CS 1.6. So far i am looking hard into these headphones. If none of these are good then you can suggest any and price dosent really matter.
1) Sennheiser HD 580 (no mic)
http://www.newegg.com/Product/Product.asp?Item=N82E16826106303
2) Sennheiser HD 595 (no mic)
http://www.newegg.com/Product/Product.asp?Item=N82E16826106390
3) IceMat Siberia without the sound card
http://esportsea.com/index.php?s=proshop&d=product&id=67
4) IceMat Siberia with the sound card
http://esportsea.com/index.php?s=proshop&d=product&id=75
5) Steelpad 5H without the sound card
http://esportsea.com/index.php?s=proshop&d=product&id=70
6) Steelpad 5H with the sound card
http://esportsea.com/index.php?s=proshop&d=product&id=74
If none of these are good please feel free to suggest good ones also what is the difference of having the sound card come with it and buying one that dosent. I currently have the x-fi fatality sound card. Also for the headphones without mics can you guys suggest good ones for me.
Thanks Alot!!
Thanks Alot!!
