Which one?
HatefluX
http://samsung.com/Products/TV/LCDTV/LNR268WXXAA.asp
http://www.bestbuy.com/site/olspage...CategoryId=pcmcat39100050030&id=1125466651583
http://www.viewsonic.com/products/desktopdisplays/lcdtv/n2050w/
or
http://www.viewsonic.com/products/desktopdisplays/lcdtv/n2750w/
This is only for gaming, xbox, and PC. I already have a 930B but want widescreen with the ability to hook a console to it. I have been pouring over these forms for a week and would have already gotten the Gateway but someone here said that the Xbox via component in this monitor was way to dark. Has this been confirmed?
Thanx
Alright it sux in component, @ least for my PS2, way to dark. It also has the that wierd X pattern with the backlighting, but they may be noticable due to the brightness set to 80. Anyone with this monitor have any advice, settings for component. Beautiful otherwise.
Man the darkness problem is really putting me off. Is there a work around? When I look @ a dark spot in a game it loses all detail but if I move my head to the side it becomes visible.
Don't know weird.
Found it really dark, guess I need to play around with it. Do you have any settings suggestions??
Thanx
well..i used default settings, and with my Dish receiver, i found the quality great...via component
