Which one x800xt or 6800 Gt
Brucee
should i get you thin kis the better performer. Im jsut asking for opinions here.
If the price difference is nothing to you, the X800XT, it's as fast, or faster than the 6800 ultra, so it should be no surpise it bests the 6800GT.
Brucee said:
yea price has no difference for me.
this is the one i was thiking the sapphire x800XT
http://www.newegg.com/app/ViewProductDesc.asp?description=14-102-423&depa=0
good card? Will it perform well in doom 3 also. I have hL2 so i know it will do good there.
Yes it will play both games at max quality fine, although I dont think you can do more than 2X aa at 1600x1200, if you're going to get a vivo XT, just get a sappire X800 pro vivo and flash it, and save a few bucks.
Spin the bottle on the winner
Although I would lean more towards the XT anyway even after that statement
Unless you play ONLY Doom3....get the X800XT....that's the only game in which the GT can give a substantial lead. In Far Cry the XT owns the GT...and in HL2 you can call it...a draw.... unless you run at very high res and high levels of AA/AF (such as 1800x1440 2x 8x) where the XT will do better...
Pull that trigger, XT is the way to go for now IMO. I switched and am much happier.
