Which one to choose???? HELP
phinix
I'm gong to change my PSU for my new rig.
I will have:
Q9450 - OC'ed
8800GTS512 OC'ed - and in next few months - 9900GTX (or 8800GTS512 in SLI)
2xHDD 750GB
I have Enermax Liberty 500W right now. I need modular PSU.
I will mod the new PSU after tests so I will loose warranty - that is why I want to choose the best...
I do not want to pay a lot, so chose these options:
  • Corsair HX620W modular
  • Coolermsdter Real Power 700W
  • OCZ ModXStream 780W
  • Thermaltake ToughPower 750W
Which one would the best?
I chose Liberty 500W 2 years ago cause it was the most popular. Now Corsair 620W is very popular.
I need PSU that won't break in next year at least, cause after testinf I'm going to mod cables and chrome the cover of PSU. Corsair sells additional cabels so I could mod it without loosing a waranty, as long as I chrome new cover over the PSU...
What do you guys think???
Read customer reviews on newegg and find ones that people successfully run SLI on. Plus keep in mind that you need 4x6pin pci-e power connectors to SLI 9800gtx. You could use adapters but it's better to use an actual pci-e cord if possible because the psu is designed to give those enough power.
