which one is better?
A 6600 should be marginally quicker. If you're looking for a new AGP card for $100 though I'd take a look at the FS/FT forums and Ebay. There are quite a few 6800s and x800s for about $100.
alright thanks, basically i'm looking for an agp card for under 150 dollars, would the 6600 still be the best?
For under $150, the 7600GS is a better choice. It's far quicker than either of those two. (A little quicker than a 6800 Vanilla)
Yeah, they'll all work in that slot. The only issue is that if your system only has a 4x AGP slot it's probably not the most up to date. Can you list your system specs?
yea its a piece of crap i know, but im going off to college in a couple years so i just want to upgrade a few things, then get a new computer when i go to college. right now my specs are a 2.0 ghz p4 256mb rdram(ordering 512mb more) a geforce 4(until i buy the new card) and a 40 gb hdd that im gonna upgrade too. basically im looking at upgrading to all of this under 350 dollars, right now its at about 310
well i bought the x1600pro, was that the right decision? it was only 120 dollars i believe
X1600PRO is decent enough. What games are you going to try to play?
mainly just ut2k4, fear, bf2, and quake 4/quake 3 arena. and possibly AoE 3
