which ocz powerstream?
Rasha
im having a hard time picking between the 520 w and the 600w powerstreams i know the 600 one is 2.0 compliant but ... so what? does that actualy mean anything to me?
uhh heres a list of what im trying to put together... incase it matters
2xnec dvdrw-dual layer
dfi-sli-dr
at some time 2x6800gt bfgtech
1gb ocz pc4000 222@3.3v
2x with later going to 4x 250gb diamondmax16mb hd's
an undetermened venice cored 64
3x 120mm fans
2x 80mm fans
6x cold cathodes
8 leds in various things, feet etc.
1 musketeer
1 3.5 blue led'ed fan controller
1blue led mouse pad
1x matrix orbital v2 lcd screen
and of course the one internally mounted nec floppy
thats what i've picked out so far might change a little
with all the stuff you should go for the 600w. the 2.0 complaint is mainly related to two rails from the specs i'm looking at which is what pci-e needs.
for an SLi the 600W
but at that price point Id go for the PCP&C 510
ya i've heard really good things about the pcp&c ... eclipse if you out their chime in ???? plz??? :D
if you get an answer from ice czar you stick with that answer. eclipse will tell you the same thing.
Rasha said:
just trying to protect myself form early april foolsz
well in that case Id recommend a POWmax
guaranteed to make life interesting
ZAP :eek: snap crackle pop :eek:
:p
