"Budget" Build
9800 GTX+ 512mb
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130436
or
9800 GTX+ 1gb
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130429
________________________________________
High(er) End Build
GTX 260
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150329
or
9800 GX2
http://www.newegg.com/Product/Product.aspx?Item=N82E16814143128
Which would you pick out of the 2 options? and is it worth the extra money to go for the gx2 or 260 over the gtx+ 512mb or 1gb
9800 GTX+ 512mb
or
9800 GTX+ 1gb
High(er) End Build
GTX 260
or
9800 GX2
