I plan on putting a Noctua 140mm fan on bottom of my case as an intake fan. Amazon has several different Noctua 140mm fans, what is the difference between them and which one do I want?
Do you have a budget? Prefer noise or performance? Main difference is whether the fan is PWM or not, as well as their max rpm.
If you don't care about money and noise, I can wholeheartedly recommend the NF-A14 iPPC fan.
These fans move a serious amount of air even at 50% rpm, and barely make any noise at those rpms. Here's a video showing what it sounds like at different rpms.
would you recommend the 2000 or 3000 rpm version? I don't really have a budget, the fan I was thinking of getting was the NF-P14 FLX and NZXT Sentry Mesh fan controller with 30w per channel. I'd like the fan to be quiet.
Definitely the 2000 rpm one if you want to avoid noise.
Since you're going to using a fan controller, I'd still recommend the NF-A14 iPPC fan I linked above. Reason being you can always run a high rpm fan at lower rpms, but you can't boost the rpm beyond the rated limit. Look at these videos side by side:
Skip to the part where they show the table with the cfm/noise listing, then pause and compare.
Notice that when both fans are producing 15dB of noise, the iPPC fan is pushing 58.9 cfm while the PLX fan is only pushing 44.8 cfm.
If you need absolute silence, you can run the iPPC fan at 40% rpm, where it hums along at only 11.9 dB, but still manages to push more air at 53.2 cfm.
