Which mp3 player is better?
MikeFlide
I have a really old mp3 player (RIO riot :D ) which broke not too long ago and i want to get a new mp3 player. I have narrowed it down to 3 players. They are:
iRiver 5GB H10 Blue
OLYMPUS m:robe 100
RIO Carbon 5GB
It's cheaper at CircuitCity than at newegg.
As you can see i don't want an mp3 player with a lot of memory. 5GB is a perfect amount for me. If there are any suggestions on other players i'm open. Also don't suggest the mini. I hate the mini.
Thanx
Also just got some new info about the Carbon it not so durable. So if any of u know the durability of the other 2 plz tell me. Also If u know of any similar players in the same price range ($120-200) that is durable plz inform me. Thanx
Go with the iRiver. I have one now and, in fact, was looking to upgrade to the one you have listed.
I don't know if you've looked but check out the reviews on www.cnet.com for those players. On your point about durability, I wish some sites would do tests for that. If I find anything, you'll be sure to know.
