Which mouse to replace copperhead
gen3000
Hey,
Im getting back into gaming after a while out and looking for a new mouse. I got a Razer Copperhead but its basically broken now and I definitely need to replace it.
I guess I play mainly with my wrist instead of moving the whole mouse around and just wondering what suggestions you guys have as a good replacement for the copperhead... or is it just worth buying another copperhead?
Currently got a razer exactmat (dual sided)
well, if you claw grip it, grab another copperhead or a diamondback. If you palm it, do a deathadder. That is, if you want to stay with razer.
Logitech has mice that impress a lot of people here. While I am not a fan of Logitech, I do hope you will not limit your search to just Razer.
Another copperhead would be my suggestion. It's probably the best mouse ever made, especially now, after all the firmware fixes.
I bought a SteelSeries Ikari mouse at Quakecon, and I think it's the best mouse I've ever used. Better than my old MX518, and better than my brother's G5. Solid construction, and you can change the DPI by 1. I would highly recommend the SteelSeries.
