I was planning on getting a 3007-HC but am starting to think the 2707 may be a better choice for me.
I have enough space to accomodate either, but not enough space for a 32" 1080p HDTV as my credenza has a 30" wide space for a display and all the 1080p HDTVs are at least 31" wide.
Right now I have a Sony SDM-P234/B (1920 x 1200 @ 23"), but I am wanting something larger. The text is a bit hard for my 38 year old eyes to read at the default DPI. The DPI scaling works much better with Vista than XP, but there are still issues with wraparound and IE7, and also some windows of some other software I use. Also the zoom feature of IE7 is a bit buggy with scrolling.
The dot pitch of the 3007 is actually a tiny bit smaller than the Sony so I will definitely need to use the larger DPI and/or zoom feature. The 2707 is obviously larger and should be easy to read at the default DPI. I'm thinking the larger pixel size won't be an issue as I sit about 3-1/2 feet away from the monitor.
While I am somewhat of a resolution junkie, 1920 x 1200 is probably enough for my needs although I do multitask a lot and could make use of a larger desktop space. Also I currently have a 7800GTX and I will have to turn off some eye candy or AA if I were to run games at 2560 x 1600. With a bit of overclocking it can handle most games maxed out at 1920 x 1200. Later this year I'll probably upgrade to the 8800GTX successor when Crysis and other DX10 games are imminent. I'd prefer not to go the SLI route because of cost and heat / power, though if Crysis demands it and Nvidia gets SLI working right with Vista I would consider it. Far Cry is stil one of my favorite games...
Cost really isn't an issue, although I wish there were a bigger differential between the two. The 2707 does seem to have better build quality (metal versus plastic) and a nicer stand, to offset the smaller panel size and lower resolution. As I only plan to use a single DVI or DVI-D input, the extra inputs on the 2707 are not a big selling point to me. I have several other HDTVs around the house (including a 32" Toshiba LCD, 65" Mitsubishi 1080p DLP, Qualia 70" SXRCD, and soon a JVC DLA-RS1 projector with a 92" scree). The absent OSD and extremely limited scaling of the 3007 are relative drawbacks, although I believe this lost functionality can all be handled via the Nvidia GPU. Nvidia control panel is much improved on the most recent drivers (158.18 and 165.01) though I still miss the original one.
Anyway I'd appreciate advice from anyone who has had a similar decision, or has first had experience with both monitors. I'd like to order the monitor pretty soon, based on other comments here I will likely go through Jonathan Lucas at Dell.
