computater
- Apr 4, 2006
I'm looking around for 500W+ modular PSUs. (Budget for the buy is ~$100) I have an antec P180 on the way and since the PSU is located on the bottom and knowing my luck I'd order one and the cables would be too short.
If anyone has this case, or knows about it, I could really use some advice on which PSUs are good and have cables of sufficient length. Thank you.
(Another question I thought of: My x1900xtx requires a PSU with at least 30 amps on the 12v rail. Does this mean I need to find one that can output 30 amps from a single rail or all 12v rails combined??)
