Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Corsair's AX series is my favorite tbh, get the AX850 or AX1200. All black cables make it clean in your case, and if you got the cash and want individually sleeved cables, Corsair is selling kits for their top-end PSU's for individually sleeved cables to replace the ones that come stock.
The single OC'd ASUS 7970 system took up 600W of power from the wall.
Now if you put in another card.......well I think you would be getting very close to a REAL 650W
from the PSU, if it was 80% efficient......if you overclocked both cards using just CCC Overdrive.
I have a big system.......watercooled, OC 3930, and a bunch of fans, not to mention two 7970s.
The AX750 could probably handle it, but for $100 more why not get the AX1200? For the price difference your getting a unit that won't be stressed, will run cooler, and live longer under the load your planning. And your far less likely to encounter PS issue which are a pain in the @$$ to diagnose and fix.
Personally, I don't get the minimalist attitude when it comes to RAM and power supplies. Reminds me of my dad that would always find the smallest pot in the kitchen to cook with. I can remember him hunting for this one particular tiny little pot to boil eggs in and then only put just enough water to get the job done.
And don't get me started on what he would do with the dishwasher...
