which mobo?
qwerty.yp
Hi,
really appreciate the site. tons of useful info!
Sorry for starting 1 more thread asking which mobo i should get.
i'm a programmer and the co i worked for got bought and that didn't go so well. now i'm an independent contractor & i'm also a part time youth pastor, which means i will often have a couple of adobe products (video/photo editing, etc) open as well as vs2010 and sql mgt studio open along with 10-12 browser tabs, excel, outlook, music, etc...
i'm trying to build a really good desktop that will be fast enough for all that plus a little gaming ;)
$$ is sort of an issue so i'm going to have to do the build over a little time, so my thought is to buy a good mobo, & the cheapest cpu for the board and a cheaper video card then upgrade as i can afford it.
here's the motherboard i'm looking at: GA-X58A-UD3R - http://www.newegg.com/Product/Product.aspx?Item=N82E16813128423
its probably a little more expensive than i'd like but i want to build something that i can use for a while...
i'd really like usb3 but do i really need it?
is there something a little less expensive that i should be looking at? i'm assuming i don't want to go with an 1156 board, right?
(also any thought's on a compatible video card on the cheap would also be appreciated)...
thanks for your help!
Do you really need USB 3.0? No.
That Gigabyte board is one of the stablest X58 boards out there, it's a great choice.
If you're tight on cash, you might want to consider EVGA's B-Stock boards.
$80 (with free shipping) for the LE isn't half bad.
Only downfall is that you get a 90-day limited warranty. :(
