Which mobo should I get...
Soapy5
Im building a comp for my bro, and have narrowed it down to these 5 mobos link
with the ASUS M2NPV-VM Motherboard the system stands at $517, $550 with shipping
i really need to cut down (im aiming around 500 shipped), and Im wondering which one of the cheaper mobos are good. in the perfect world, id like to buy ECS one for 50 bucks, but i dunno how good it is. anyone have any suggestions, (they dont have to be from the five i picked)
to help, heres what the comp is looking like:
COOLMAX CS-480-Black W/O PSU Black Steel/Plastic ATX Mid Tower Computer Case
$25
SAMSUNG SpinPoint P Series HD160JJ 160GB 7200 RPM SATA 3.0Gb/s Hard Drive -
$54
ASUS M2NPV-VM Socket AM2 NVIDIA GeForce 6150 Micro ATX AMD Motherboard -
$85
eVGA 256-P2-N541-TX Geforce 7600GS 256MB GDDR2 PCI Express x16 Video Card -
$113 $10.00 Mail-in Rebate
ASUS Black E-IDE/ATAPI CD-ROM Drive Model CD-S520/A5 - Retail
$13
FSP Group (Fortron Source) ATX400-PA, version 2.0, SATA, 400W Power Supply - OEM
$37
AMD Athlon 64 3200+ Orleans 2.0GHz Socket AM2 Processor Model ADA3200CNBOX -
$86
G.SKILL 512MB 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) System Memory Model
$52 2x $104
if anybody has any suggestions for any of the other items, lemme hear em.
ps. the mobo i currently have in the shopping cart has an onboard geforce 6150 videocard.
(also all the rest of the mobos that im considering have a 6100 videocard). im wondering how good is that card? at how high settings can it play half life/counterstrike, and how will it perform with hdr enabled games? because what im thinking is if the onboard card is decently good, i can do away with the eVGA card for now and buy it later when it gets cheaper/ i get more money
Mostly everything in the list looks good, as for the Motherboard, get the BIOSTAR TForce 6100 AM2 it's one of the best AM2 boards available for that price range.
I think you should try and go for a gig of memory, but I can't really find anything that can make the entire system close to what price you said.
just to clarify, there is a gig of memory (two 512 sticks)
speaking which, what is better: two 512 sticks to be used as dual channel, or one 1 gb stick and maximize upgradablility (aka use less ram slots)
I'd have to go with ASUS for reliability and stability. They have decent support as well if the board is bad or goes bad. Sent my friend a new board once just on his word. :cool:
Absolutely do NOT buy that Asus board.
I just did two builds with that board, and I have never seen a board be so finicky about ram. I bought the same exact components for both of these builds. The memory wasn't working on the first build, so I put in the other pair and it worked. I went through two sets of memory from Fry's for the other board, and both didn't work. I then went through two sets from Newegg, and still didn't work. I swapped the motherboard for the same one, and still didn't work. I then went ahead and swapped the board for an MSI board (K(N SLI Platinum), and with the newest bios upgrade both sets of memory worked just fine. The odd thing was that I tried the Patriot & Mushkin sets of memory in the first build, and they came up looking bad, but both sets worked like a champ in the MSI. You'll see the same things being said in the review section for that board at Newegg.
