First a little background on what I am aiming for with this system and how I will use it:
1)Must be able to be a good setup for 2-2.5 years
2)Low Noise/Heat would be nice but is not critical
3)Best Value for my money
4)Gaming is not my number 1 priority(although I do game some)
5)Day to Day stuff would be primary use(5-6 apps at once); some encoding.
All other components in these two systems would be the same so I will leave that out. RAM would be 512MB and probably some more later, when the wallet permits.
Setup 1:
ABIT "AN7" nForce2 Ultra 400 $99
AMD Mobile Athlon XP 2500+, 266 FSB, 512K Cache, OEM $88
Total: $187 +HSF
Setup 2:
ABIT "IS7" i865PE
Intel Pentium 4/ 2.8C GHz 800MHz FSB, 512K Cache, Hyper Threading, Retail
Total: $271
Now I don't know to much about which Intel chipsets are the good ones, so if there is a better chipset choice for not too much more I would consider that.
The AMD motherboard has Soundstorm according to the website, which I have heard is very nice and I do listen to lots of music. So that may be something to consider
I figure with the cost of the HSF factored in for #1, Setup 2 will end being about $50-60 more than setup 1.
Which would you choose and would it last for the time-frame I am hoping for?
Thanks in advance.
Setup 1:
Total: $187 +HSF
Setup 2:
ABIT "IS7" i865PE
Total: $271
Thanks in advance.
