which mobo for this rig ?
Vesqwi
N.B:
Because I have almost zero knowledge in Motherboards and their impact on the system, I need concret arguments for any suggestion. All I know for sure are my needs and requirement:
If that can help: I won't do any video encoding, graphic design and such demanding task. The rig will be a pure gaming rig (single screen)
-must be Intel LGA 1155
-must let me crossfire 2x Radeon HD 7970 GPU (I don't need much more slot, I prefer to replace rather than add more GPUs SLI/CF)
-must let me Overclock both my GPU and CPU
-must be SSD ready
-must support DDR3 1600Mhz 8Gb dimm up to 32gb
-would be good if support the next Ivy Bridge CPU)
- No need for: PCI 3.0 support
- No need for: SDD Caching feature (unless it might be proven to be usefull for loading games faster ? .. which I doubt cuz they will already be installed on my sdd)..(won't have any HDDs)
- No need for: Raid support
- No need for: Surround Sound support
CPU: i7 2700K (or maybe 2600K)
GPU: AMD Radeon™ HD 7970
Memory: 16 GB DDR3 1600 MHz (2x8GB)
HD: 160Gb SDD
PSU: 850W or 1000W
OS: Win7 64bit
Mobo: ? ? ? ?
What do you guys suggest me ?
Also, if you happen to be near a MicroCenter they have a good combo deal on 2500k/2600k CPU and motherboard. Plus their prices are cheaper to begin with.
For example the 2500k is $179 and 2600k is $279 and you get $50 off any compatible motherboard.
Got no MicroCenter in Canada. But I might use bongous.com to get the 7970 anyway cuz it's not sold anywhere in Canada.
A budget P67 or Z68 board will be enough for you based on what you need.
3D and multi-monitor are based on vid card and monitor.
Surround is more based on a sound system you'd hook up to your computer.
How about one of these:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131781
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131770
Thanks for your suggestion. But can you help me define what features I'm looking for in a mobo ? Actually I have no idea how to compare any mobo... like those 2 and the P8Z68-V/GEN3 someone recommended me earlier.
Thanks
ASUS P8Z68-V PRO/GEN3 is a pretty well reviewed board. I have one myself and haven't had any problems with it yet. I haven't OCed yet as I am waiting for my CPU cooler but from everything I read it should be good.
If you really want 3 or 4 way CrossFire, you are going to want a board that either has a multiplexing switch like the NF200, or a X79 system. Otherwise you are going to run into pretty serious bandwidth limitations with those third and fourth cards hanging off the PCH.
That's the Republic of Gamers board, and includes a lot of stuff that you almost certainly don't need, like the ROG Connect and smartphone connectivity, along with quad-SLI and dual ethernet ports. It may also overclock a little bit better (like 5.2 instead of 4.8 or something - only noticeable if you are going for extreme overclocking).
No way I'd pay double for that board.
Just updated my 1st post (requirement list for my mobo)
Actually I'm lost more than I was at first.. :S
help me
Great thanks ! that helped
however, I don't see why I would go Z68 over P67...
see that guys's post:
I've been doing a lot of research over the past few days.
I chose P67.
Z68 would be the choice if:
1. You wanted to take use of on-board graphics.
2. You wanted to pair an SSD with an HDD to boost the speed of the HHD. This is still slower than using an SSD as your only primary drive.
3. You want PCIE 3.0. The only gain over 2.0 comes when you use your GPU for computational stuff, NOT gaming. It will likely be a few years before games/cards can reach the limits of PCIE 2.0
4. You want a board with the Intel SATA III controller instead of the P67's marvel controller.
Z68 is newer, for one, so it seems likely that manufacturers will provide better BIOS support for it in the long run. It is basically P67+, so you aren't losing anything by going Z68, and it gives the option of using the IGP in case something happens to your main GPU. Price-wise, you can save some money with P67, but the difference isn't as large as it used to be.
Also, Z68 boards seem to have better support for Ivy Bridge (although we'll still have to wait and see for sure) along for support for PCIe 3.0 (some P67 boards also, but not as many).
Short version, there is no downside to Z68 except price, so if that isn't a big concern for you, go ahead and get the Z68 board.
just added this to original post:
Required:
- Enough space to crossire 3 to 4 7970 card (should'nt go over 2, unless benchmarkers can prove the
worth of a 3-4way crossfired 7970 in the future)
THen you can only do things like Asrock Extreme 7 or other boards that have NF200 chip. Otherwise running more then 2 cards will run out of PCIe lanes. It's SB, you get 16 lines from CPU, so you need board that will give you "moar linez" for more cards.
If you, however want really to do 4 or 3 7970 cards, I'd suggest SB-E, that will give enough lines, and won't put you into low bandwith problems.
Updated 1st post, (won't go over 2-way GPU)
Also, Aren't Asrock the low-end models of Asus ?
