Which mobo for my gaming rig
Krypto
I plan on getting either the 3200+ or 3500+ winchester cpus. I need to know which board would be best, not to much into o/c right now. Which one do you think?
MSI "K8N Neo2 Platinum"
ABIT "AV8" K8T800 Pro
Or can anyone suggest a better board? I'm looking for optimal performance. Hopefully you should know, but this is for a 64bit rig.
the neo2 or if you want PCI-E or SLI wait for the DFI 939 boards to come out.
I was told that making the jump to PCIe wasn't worth it right now, that the PCIe 16x was just as good as 8x AGP right now because none of the video cards actually use the full power of either of them.
Is it true that the Asus A8N-SLI has a 2000mhz FSB?
I have heard lots of things reguarding MSI boards, some poeple say they are very good others say they suck...that's my reason for throwing in the abit. Never had any problems with abit so far...
But I want to know your people's opinions.
MSI makes really good boards, and PCI E is something i would be looking at if i was spending alll that dough on a good chip and motherboard.
I just got my A8n-SLI board to work great. I have it at 250fsb so the memory is at 500@1:1. That paired with a FX-55 and a 6800GT@430/1200. Its a great gaming rig, exspecially if you put 2 6800GT in!
Pretty sure I want to stay away from PCIe right now, so I just need to know what is the best motherboard out there.
Epox "9NDA3+" Anyone heard anything about this board?
I will most likely be getting a 6800ultra as tripp pointed out. If I have to I can use come of my upgrades later on if I need to switch to PCIe for some reason.
C'mon, I need to know by this weekend, what is the best non-SLI non-pentium motherboard out there? Someone help me pick one !
lol sorry to intrude on this situation you got going on here, but did i just read correctly? 2 6800GTs? Thats trippy...how does that work?
Someone hasn't been reading about nVidia's SLI. :D
2 PCI-e cards (6600GT and 6800 series only) connected with a special internal piece running with each other to effectively balance rendering. It's only supported in NForce 4 SLI chipsets (NForce 4 Ultra with a modification) and doesn't give you a significant boost unless your game supports this technology. This isn't possible with AGP cards (obviously).
Neo 2 isn't PCI-E, it's AGP.
And no, don't get the asus board, wait until other contenders join into the ring
